High Octane Gas
Old Oct 27, 2003 | 02:10 AM
TRX500's Avatar
Default High Octane Gas
Would 110 octane gas hurt my V? Help it? I have heard that it would run cooler with it... is this true?
Old Oct 27, 2003 | 02:14 AM
Doctor1's Avatar
It would have no effect what so every either good or bad basically you would be wasting about 4$ a gallon on this. A couple month's ago had a fuel cell foam come apart in a drag car so the gas in it was unusable so I took it and filtered it out and put it in the V it was 118 octane and went through the whole tank and could see no difference in any thing what so ever. The gas will have no effect on cooling either the cooling is based on rich/lean condition all the octane does is determine the rate at which the fuel burns.The only time you need to use higher octane is when you have more compression no other reason than that basically.
Old Oct 27, 2003 | 10:47 PM
Mudfoot's Avatar
Doc....it smells so good though.
Old Oct 27, 2003 | 10:59 PM
Doctor1's Avatar
Yeah I love the smell of Sunoco purple 118 [img]i/expressions/face-icon-small-smile.gif[/img]
You can experience wonderful smell's at the drag strip.
The only place that smell's better than the Dragstrip is Cheetah 3 here in Atlanta [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 28, 2003 | 01:26 AM
IMPORTH8R's Avatar
Actually, running high octane without high compression will also slow your machine down somewhat also. Slow burn = less power with yhe same compression ratio as say, 89 octane.
Old Oct 28, 2003 | 01:28 AM
maddog56's Avatar
higher octane is better up to the point of detonation prevention. after that its overkill and a waste of money. Most quads with a 9 to 1 compression will run just fine on regular or midgrade gasoline. 10-1 usually works well on 91/92 octane, premium in most states. Higher than that is a case by case. some will take 104, some need 118, and others in the middle. anything higher than premium on a stock quad is just a waste.
Old Oct 28, 2003 | 03:27 AM
thomez's Avatar
The high octane actually is cooler ... but I'm not going into the details of that mess. It is a complicated web and not really needed here. Run the lowest octane that will prevent predetonation. Bottom line.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
