i have a serious problem. i need answers fast.
wow, sorry for that.
anyways, my problem is this.
i just got my atv back from having the engine rebuilt. My buddy and I did all the work. The things we replaced are:
2 kickstart gears, output shaft, input shaft, 2 shift forks, a few other gears in the motor, clutch, clutch springs.
my problem is this:
i started the atv, Took it for a quick ride to see if it was all better. I pulled it out of my yard, got it up to 3rd gear. Then all of a sudden it stalled and now it wont come out of 3rd gear. if you try to shift down or up it sounds just like when you are in neutral and you try to shift into reverse without turning the ****.
anyone know what this could be?
the quad is an 87 mojave 250.
jeff
my problem is this:
jeff
good luck. my advice is to look for a used but good running engine for it. i have seen them for maybe $350
we are gonna check it out today.
jeff
