slow mojave
Old Nov 22, 2003 | 02:03 PM
  #21
huskerjim's Avatar
Default slow mojave
Yes, I would say you have the set up the way it should be Harden valves just aren't good enough for the Mojave you need stainless steel ones to keep the mushrooms away.....
Old Nov 23, 2003 | 06:33 PM
  #22
haywoodjalikme's Avatar
Default slow mojave
The only cam dimension I can find is the height
Intake and exhaust both 35.106-35.248 with the service limit of 35.010 from the service manual.
Old Nov 23, 2003 | 06:37 PM
  #23
mojavekid13's Avatar
Default slow mojave
I have had my mojave 3years and drive it HARD at least 4-5 days a week and i have not once had teh valves adjusted or checked
should i have it done soon?
Old Nov 23, 2003 | 07:30 PM
  #24
reds650's Avatar
Default slow mojave
http://www.webcamshafts.com/kawasaki-atv.html#1[/L]
Old Nov 23, 2003 | 07:31 PM
  #25
reds650's Avatar
Default slow mojave
cams
Old Nov 27, 2003 | 07:57 PM
  #26
hilbilly's Avatar
Default slow mojave
hey kwackermann, Iv ran into another problem with wy MO. if I ride a wheely or do a jump it will bog and spit and sputter I can only go for about 10 feet and it does that. Well if u can help that would be great. THANKS
Old Nov 28, 2003 | 12:20 AM
  #27
kwackermann's Avatar
Default slow mojave
Hmm-- it sputters after roughly 10 feet doing a wheelie. Sounds like ya might be running a bit rich, alot rich really-- or the float set too low, allowing fuel to puddle in the carb bowl....
Old Nov 28, 2003 | 03:05 AM
  #28
huskerjim's Avatar
Default slow mojave
Can I comment on the sputter after 10 feet? Not run right, it's proubly not the float more than likely it is water or dirt junk in the carb, take the carb apart clean it blow it out with high pressure air make sure youy blow out the jets ok and replace gas in the tank, if it does it still email me back ok, change the plug for kicks too, ok thx hope that works for you. If you never messed with the float it should not be a problem.
Old Nov 28, 2003 | 09:32 AM
  #29
Default slow mojave
Love this Mojave forum- OK, I'm lookin' to uncork my 'jave a little more with a KLR CDI box, then some cams- in that order. But first I'd like to get those stainless steel valves- to avert disaster. Where can I get'em? Also- anyone have the stock 'jave camshaft specs- lift, duration etc..... Thanks
MooseHenden
Family ATVing Photos
Oct 5, 2015 08:14 AM
ReconBayou
Sep 23, 2015 02:41 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
firsttimerider
Sep 20, 2015 09:07 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
