belt question
Old Dec 3, 2003 | 04:45 PM
prarie700's Avatar
Default belt question
i was out riding my p700 this past weekend and a friend of mine got stuck. went to pull him out and the belt started smoking. i immediatley stopped pulling but after that happened when i take off slowly it feels like the belt is grabbing funny. does anyone know what i have done? what do i need to do to fix it? thanks
Old Dec 3, 2003 | 05:12 PM
TriumphDude's Avatar
You burnt it in one spot. It has a low spot, where the belt did not move and the pulley spun, heating up the belt in one spot. Now the clutch rattles when the low spot comes around. Time to buy a new belt. Sorry, it must have been on the loose side from the factory. Nothing new......
Maybe it isn't as bad as mine, when I smoked it, doing the same. I got the dealer to warranty it. Try to make them. Tell them it was loose. How many miles/hours on it?
Old Dec 3, 2003 | 05:32 PM
prarie700's Avatar
that sucks. i figured it was something bad. i only have about 48hrs on it
Old Dec 4, 2003 | 06:24 PM
MikeyBoyesq's Avatar
In case the dealer won't cover this under your warranty, you might be interested to know that a new P700 belt is about $64 from Tracy's World of Cycles (1-800-860-0686). I haven't actually called them for their price, but that's the price I've seen posted on this forum recently.
Good luck!
Old Dec 4, 2003 | 07:11 PM
ElectricShift's Avatar
How did you finally end up getting your friend out?
Old Dec 4, 2003 | 09:08 PM
LuvDaMud's Avatar
I don't know if this is your first belt driven bike you've had , but it takes some
getting used to. A belt drive bike ,when you press the gas , the wheels
must turn. You can't just ease in the gas slowly while pulling a stuck bike
like you would a semi-automatic like a Honda. When you press the gas ,
the tires must spin. You don't have to slam the throtle but still give
enough so the tires move. A belt drive is not like a clutch; it's not
designed to slip. it does'nt take much slipage to smoke it and then
the damage is permanent on the belt.I pulled out a polaris Rancher
out of a bog with my P650 once without smokin the belt. I spun the wheels
a lot but still got the job done.
Good Luck.
______________________
2003 p650 red
holeshot module
Dalton springs
26in Bear Claws
ITP cast alum. rims
Full equiped
1999 300 honda 4x4
full equiped
collecting dust since P 650 in town
Old Dec 5, 2003 | 01:02 AM
prarie700's Avatar
i think the dealer will replace the belt under warranty
Old Dec 5, 2003 | 01:04 AM
prarie700's Avatar
i used the winch which i should of done in the first place.
Old Dec 5, 2003 | 01:09 AM
prarie700's Avatar
yes this is my first belt drive. i was pulling a bayou 220 that was buried in a creek bank. thought i could just pull it out because it was so light. but i was wrong and i know better the next time.
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
stcspiderman
Sep 13, 2015 05:15 PM
Logan Collins
Sep 5, 2015 08:03 PM
