spark plug
Old Dec 5, 2003 | 07:18 PM
sledgehammer650's Avatar
Default spark plug
If you want to read the plug on the 650. How do you go about checking it? Ive read alot about jetting and reading the plugs colors,but when is the best time to pull the plug and check it. Thanks
Old Dec 6, 2003 | 05:15 PM
Default spark plug
I'am not sure if you guy understand what iam asking. I read somewhere that if i checked the at idle for some time that that would give me a false reading. That i should ride it down the road a bit then check the plug. At what phase will the plug reading be correct. Thanks!
Old Dec 6, 2003 | 06:48 PM
Kawi650's Avatar
Default spark plug
I wouldn't run down the road then check your plug when I check mine I run it good and let it sit until it's cool. Since the plugs are so hard to get at I don't check mine frequently. the front one is easy the back one is hard. I feel letting a 650 just idle is hard on your plugs. I tell if my jetting is off by the feel of acceration and listening to the bike.
Old Dec 6, 2003 | 07:27 PM
reds650's Avatar
Default spark plug
Run wot for as long as you can [30sec will do] then hit the killswitch without letting off come to a stop with the bike not running pull plugs and check them. this if for the main jet
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
