VForce Clutch Enhancements
Old Dec 6, 2003 | 09:29 PM
DennisCummins's Avatar
Default VForce Clutch Enhancements
I just bought a KFX700 and am looking to do some clutch upgrades, like most of you have done, but where are some good sources to go to, to order the springs. Bright Green, or Pink, or ect. I already have Dalton, but I am looking for some others.
Thanks
Old Dec 6, 2003 | 11:43 PM
SandSam's Avatar
EPI for the green and pink.....HPD for the plain
Old Dec 8, 2003 | 09:46 PM
Great, is there a web site for these companies?
Old Dec 8, 2003 | 09:51 PM
bigcreek1's Avatar
click Hpd clutch springs
Old Dec 8, 2003 | 10:07 PM
bigcreek1's Avatar
EPI SPRINGS
click here
Dalton probably has one of the best mods for the money with the lighter clutch cover.....(bottom of page)
click and scroll
Old Dec 8, 2003 | 11:21 PM
Thanks for the help! How easy are these to install? Do they come with directions or could most any half way intellegent person figure it out?
Old Dec 9, 2003 | 09:04 PM
How important in replacing the secondary spring? To the "Black" spring?
Old Dec 9, 2003 | 09:23 PM
bigcreek1's Avatar
Very easy to install, just note that the large bolt through the center of the clutch loosens clockwise. There's an arrow on the clutch cover to remind you. You will need simple tools: a phillips screwdriver, a set of metric sockets with long extension (to remove a couple bolts in the cvt cover) and something to use for leverage. I used an old large screw driver. Begin by removing the vent tube from the top rear of the cvt cover(phillips screwdriver to remove clamp). Next, remove all the bolts in the cvt cover. Wiggle the cover a little and remove it. remove all the small bolts in the clutch cover 10mm I think. Now you will need some form of leverage. This is where I routed the large screwdriver through the "cvt cover guard" and the clutch. Be careful not to bend anything. It will take quite a bit of force to remove the first time. Now, remember what I said above about loosening large bolt clockwise. remove the bolt (19mm I think). You are in! Replace spring and reverse steps above. Really quite simple once you do it. KevinM has pictures below:
click here
Old Dec 9, 2003 | 10:35 PM
PsychoATVMan's Avatar
Sine the subject is springs..if i ride mostly trails and do some drags what color/brand of spring would you recomend? im new to this whole "spring" thing [img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 9, 2003 | 10:43 PM
bigcreek1's Avatar
Hey psycho, do some searches in here under primary spring and clutch spring........ tons of info. These are fairly inexpensive to experiment with. Hope this helps.
