Raising compression on Mojave
Old Dec 16, 2003 | 09:37 AM
kwackermann's Avatar
Default Raising compression on Mojave
Is there something like a thin head gasket I could get somewherethat would raise the compression of the Mojave? I'm fixing on moving to the high country- so I'll need all the compression help I can get....... Thanks
Old Dec 16, 2003 | 09:41 PM
boob's Avatar
domed piston and decking the head
Old Dec 16, 2003 | 11:31 PM
Chris142's Avatar
Don't go overboard. The compression is 11:1 stock.
Old Dec 21, 2003 | 04:46 PM
Hey Boob- deck the head how much, I can getmy hands on an 11:5 piston, I'd like to get 11.75:1 compression ultimately. Oh yeah-- and do your oversized valves make a difference, and what carburetor do you have? Thanks............
Old Dec 21, 2003 | 06:25 PM
boob's Avatar
i couldnt tell you about the valves cause i had all my work done at the same time , i am running the stock carb with a dynojet kit and i dunno about how much to deck the head sorry
Old Dec 21, 2003 | 06:31 PM
Chris142's Avatar
Alright listen to me.
Going from an 8:1 compression ratio to say 10 or 11:1 will improve power slightly.
Going from 11:1 to 11.5 or even 12:1 wont make much difference.
Once you get past 11:1 any power incease due to compression is neglagable.
Personally I don't think it's worth your time and money to increase the compression according to elevation.
Old Dec 21, 2003 | 06:49 PM
Thanks for the illustration, chris- I'm looking for increase in compression because I'm fixin' to move to the high country, 7,000 ft+. Also I am going up in camshaft and so fourth. I just purchased a KLR CDI box which has no rev limiter, so at higher RPM's there is less time for making cylinder pressure and hence my reasoning for additional compression.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 22, 2003 | 03:17 PM
mojaveaddict's Avatar
compression will make a significant difference in power and the more you have the more power you will get, BUT when go past 11:1 you will need racing gas. Are sure sure you want to pay the price of race gas all the time. I did put a 11.5 wiseco in one of my mojaves and with a big cam that bleeds of pressure you can get by just barely with 93 octane pump gas.
Old Dec 22, 2003 | 04:34 PM
Hmm-- that close to the edge on 11:1 as it is.... OK, 'addict- how about 11.5:1 piston, premium gas with a bottle of ctane booster thrown in- I'm goin' to the high country so I'm thinkin' that I should be able to get away with that, goin' with the .380 cams, but say I don't make it- can I add another gasket then to bring the compression down, or is there a think gasket out there? Thanks
Old Dec 22, 2003 | 05:09 PM
sickmojave's Avatar
octane booster will do nothing good for you.
