P650 lower crankcase noise
Old Dec 27, 2003 | 03:16 AM
Customfabandweld's Avatar
Default P650 lower crankcase noise
I just got a new P650, and I really like it, but it's making a knocking noise coming from the crankcase. It is pretty loud when it's cold, and I can still hear it a little when it's warmed up. This is all happening in nuetral. Is this normal?
Old Dec 27, 2003 | 07:57 AM
krabidKVF650's Avatar
If it is only when idleing and more to the right side it's a good chance it it the drive clutch. To get rid of it you have to change the slide buttons that are between the spider and the sheeve. There is a little too much clearance there and the drive sheeve is the cause for the knock.
Old Dec 27, 2003 | 11:39 AM
DaveC's Avatar
Even though it's new it needs new buttons????
My P-650 has the same noise and did so when I got it with 56 miles on it. I was also worried about it knocking, but have learned to ignore it figuring it was just one of the lovely noises coming from the CVT.
Should I be worried?
Old Dec 27, 2003 | 11:43 AM
PROCHARGER's Avatar
AFTER ABOUT 4MONTHS MINE HAD A WICKED NOISE COMING FROM THE SAME AREA. SOUNDED LIKE A ROD KNOCK . ESPECIALY WHEN COLD. I BROUGHT IT IN UNDER WARRANTY AND IT WAS THE CLUTCH SLIDES. THE TERM USED WAS WAY OUT OF SPEC.
Old Dec 27, 2003 | 12:48 PM
The buttons are how you set the clearance on the clutch slide. Standard clearance is over 0 to 0.0047 in. There are 9 different thickness buttons to set the correct clearance. It doesn't have to be much over spec to get the knocking noise. The noise you will hear when it gets too much clearance sounds like a rod knock.
Old Dec 27, 2003 | 08:07 PM
Cleve's Avatar
Without having a service manual(which is next on the must get list),is there anyway of getting a pic of what is being described to remove one of those buttons?
Old Dec 27, 2003 | 09:00 PM
Is the dealer going to take care of this, under warranty?
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Ahtatu
Sep 28, 2015 12:14 PM
