Post here if you have had transmission problems.
Old Jan 1, 2004 | 06:15 PM
cueball89's Avatar
Default Post here if you have had transmission problems.
I was wondering how many 650 owners have had transmission problems with low range. Maybe if there are enough kawie will have a recall.
thanks
Old Jan 1, 2004 | 08:17 PM
hammerman's Avatar
I have a 03 650 that low range pops out. It is at the dealer and I am having trouble getting it fixed. I have the extended warr. My front motor mount is egg shaped and keeps coming loose. My dealer tightened up the bolt and
is trying to charge me for It. I am going to contact kawasaki monday.
Old Jan 1, 2004 | 09:40 PM
SHOTGUN's Avatar
count me in!
Old Jan 1, 2004 | 10:47 PM
cueball89's Avatar
Mine makes a terrible noise in low. It slips in and out at 10+mph in 4wd and 2wd. Adjusting the shift linkage did help some.
Old Jan 2, 2004 | 09:41 AM
roscoe69's Avatar
count me iin, but we are still waiting on the choke recall thing.
Old Jan 3, 2004 | 03:47 PM
Kawi650's Avatar
Are you talking about the lower part of the engine where the dog gears are or are you talking abou the cluch? Sorry guys but I have 20000km on my 02 650 no trans problems only clutch slipping issues. Mine jumped out of gear twice in it's life both when I was in low at higher rpm. I think your gear adjustment has to be looked at. My dealer grinded a little more around the edges on my low range spot.... I'm wondering if this is what you need to do. Cue: it takes a long time to adjust the adjuster... I found you adjust it, ride it, adjust it, ride it etc.. soon you would get it. and cue is your engine brake bearing good cause that will make a racket at 10mph in low.
Old Jan 3, 2004 | 08:24 PM
cueball89's Avatar
thanks kawie650, ill have to check it out.
Old Jan 5, 2004 | 09:56 PM
roscoe69's Avatar
i find this hard to believe,only five bikes, ok lets say post here if you are going to have problems in the near future, damn now i did it, now everyone will be posting
Old Jan 6, 2004 | 09:01 PM
Syrupdawg's Avatar
I have a P360 that is 1 year old. It is a 03 model and it messes up actuators of something like that really bad. Any other owners have this problem?
Old Jan 7, 2004 | 09:20 PM
TellicoGrizz660's Avatar
Problems with the Prairie??????
