Initial tune-up question on my 700?
Old Jan 13, 2004 | 11:54 PM
Kawi650's Avatar
Default Initial tune-up question on my 700?
i was shocked on my first sevice too... but I glad it's done.
Old Jan 14, 2004 | 04:55 PM
bandit33's Avatar
Hmm, guess it doesn't look THAT hard... I'm not great at fab work tho... I'll do a K&N and the DMC's what do I do for the jets?? as in size?? Or do I buy a kit with various sizes or ?? I run a few 1000 feet above sea level for the most part... 2-4000 sometimes as much as 6 tho
Old Jan 14, 2004 | 05:14 PM
XC800's Avatar
Originally posted by: MikeyBoyesq
XC800,
He11 I know a guy who used to load his snowmobile and take it to the city to have the drive belt changed!!!
You pickin' on Alltoys again? You know he's embarrassed about his lack of mechanical skills!
Just kiddin' [img]i/expressions/face-icon-small-smile.gif[/img]
Now that funny, Good to see a little humor on this site now and again!!!![img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 15, 2004 | 02:26 AM
alltoys's Avatar
Mikey, XC800,
Both Jokers I see, yes it is good to see a some humour going around. Where is Scootdog when you need him!!
Old Jan 15, 2004 | 02:27 AM
  #15
Raptor010101's Avatar
I don't know if the needle position has to be changed but i have always found that a dyno jet kit is well worth the money. the advice they give you also is backed by alot of research a far as what jets to use for what mods. but i don't know if they have one for the prairie 700 yet?
Old Jan 15, 2004 | 02:42 AM
  #16
alltoys's Avatar
Raptor,
Hate to burst your bubble but Dyno Jet jets suck. The largest jet is smaller than the OEM stock jets that come with the quad I have said this many times in the past. If anyone wants I have DJ jet set for sale. The only thing that is half decent in the package is the needles to allow for setting the mid range fuel flow. The same thing can be obtained by putting washers on top of the OEM needle a lot less expensive than the DJ kit. You can buy a complete set of OEM jets for a fraction of the cost of the DJ kit. The DJ system needs to be updated considerably definitely not worth the $100.
Old Jan 15, 2004 | 11:20 AM
  #17
O.K you have gone to far with this by saying the main jets are smaller than the stock jets, If that were the case everyone would have ruined their motors along time ago by running lean. Dyno jet uses their own numbering system so people cannot just buy oem mains to copy their jetting reccomendations thats why the numbers appear smaller but the jet are definately larger. the needles are the most important part of the kit but for a guy tht does not wnt to change jet 3 or 4 times to tune it in dyno jet is the way to go because they do the testing so you don't have to. and as for $100 rocky mountian catalog lists the K/N p700 kit for $59.99 which is believe is the same as a dynojet kit.
Old Jan 15, 2004 | 12:18 PM
  #18
trx450's Avatar
bandit33--- BACK to your original question. The 1st service is just a glorified oil service. Change ALL the lubricants, change oil filter, check brake adj. (rear), check brake fluid level,look at air filter(clean as needed), check for coolant and oil leaks,and kick the tires! No valve adjustment is called out in the factory service manual at this time. You can do this service yourself for about $25.00 worth of oils, and filter. If you are gonna do your own work, I recommend buying the Factory Service Manual($40 or so). Save ALL your parts receipts, just in case you have a warranty issue.
Old Jan 15, 2004 | 02:45 PM
  #19
alltoys's Avatar
Raptor,
Just for the heck of it physicaly check the size of openings in the DJ jet kit then check the openings in the OEM jets then get back to me.
Most people want to jet up because they have modded their muffler, intake, the basic modding stuff. If you want to rejet because the bike is running rich from factory and the elivation determines this. Yes you can use the DJ system because they are a less flowing system which is better for a quad that has no MODDS only because the quad is set from factory with a rich setting. How many quad owners change their jets because they are running a stock set up...........?
Old Jan 15, 2004 | 02:58 PM
  #20
Mike04v700's Avatar
I am relatively new to ATV's and jetting, but I have witnessed for myself and seen other discussions stating that since the DJ needles are smaller than stock the overall opening for fuel flow is the same as the larger stock jets and needles. Like I said though....I am new to this stuff and might be overlooking something.
Mike
