how to jet a mojave
Old Jan 17, 2004 | 07:16 PM
shoemaro's Avatar
Default how to jet a mojave
I have a 92 mojave and im upgrading the cams, removed rev limiter, supertrapp pipe, k&n clamp on filter. I have a 38mm pe carb, but i think i'm going to use a 400ex carb, or maybe 36mm mikuni from cwr. What carb would be the best for the mojave, and if i used the 400ex carb, could i buy a jet kit for the 400ex to jet the carb on the mojave with my upgrades.
Old Jan 17, 2004 | 08:46 PM
mojavekid13's Avatar
Now that will be a tricky task!
Old Jan 18, 2004 | 01:58 AM
toyaddict's Avatar
Yes, you just use a jet kit for a 400ex, but you should buy a big kit, cause you will have to try several sizes to get just the right one, The cam manufacturer should be able to get you close if you tell him you have a 35.5 mm carb with accelerater pump. Hope this helps.
'01 mojave
FST 411 stroker
FST cams
FST cdi box
400ex carb
K&N slip on air filter
Works shocks
Maier race cut black plastic
Old Jan 20, 2004 | 11:17 PM
shoemaro's Avatar
will a kn clamp on filter made for the mojave, fit on the 400ex carb. i know the 400ex carb is 1.5mm larger than the mojaves.
Old Jan 21, 2004 | 08:49 AM
kwackermann's Avatar
Getta 400ex carb, man! It's the way to go............
Old Jan 22, 2004 | 07:20 PM
shoemaro's Avatar
what kind of wheelie power should my mojave have with my supertrapp pipe, cams, removed rev limiter, kn clamp on filter, and 400ex carb. What gear will it be able to wheelie at.
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
RidE
Oct 19, 1999 06:10 PM
dunc_n
Aug 26, 1999 09:32 PM
BlackHawk
Jul 31, 1999 01:31 AM
