Help me build a plow mount for a 700/650
Old Jan 30, 2004 | 07:51 PM
Raptor010101's Avatar
Default Help me build a plow mount for a 700/650
I have a cycle country plow set up but need to mount it to my p700, What ideas do you guys have on how to build the mounts, looks like moose uses a solid plate on the bottom or something??? wouldn't that block air flow?
And cycle country has some goofy system on the floorboards which don't look real strong?? both are about $50.. crazy money for a bracket. Help..........
Old Jan 30, 2004 | 08:37 PM
mrh's Avatar
mrh
I have the CC ones and you could probably build something stronger, but I don't think you really need anything stronger.
Old Jan 31, 2004 | 01:31 AM
kawiyowee's Avatar
I also have a cycle country plow (60" steel) and have plowed fairly hard using CC's floorboard brackets. They went on easy, work just fine. I happen to be a structural engineer and looked at the brackets closely when installing them. Don't think you would have any problems with them strength-wise.
CC recommends removing them for ground clearance after plowing season - something to keep in mind if you're going to build your own.
95wolv
Sep 27, 2024 12:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
EIF
Apr 20, 2017 07:15 PM
rcappie4
Sep 9, 2015 07:04 PM
