new v-force help
Old Feb 8, 2004 | 01:51 AM
Rkhard's Avatar
Default new v-force help
wow while i understand some of this most is greek.. my last time messing with a quad was when i was 16 and im currently 29 so thats some years ago id be interested in getting with some of you smart people via icq at 312820361 also mark i see your in PA im origanlly from PA and will be there with my V-force the 23 of this month looking for a place to ride while im on vacation perhaps you can suggest somewhere... hope to hear somthing from someone on icq as i dont want my quad sitting stock for very much longer
Old Feb 8, 2004 | 10:37 AM
Quadfather's Avatar
RkHard: I sent you a private message
Old Feb 8, 2004 | 12:56 PM
jetratt's Avatar
Hey MentalState,
Is changing the primary spring all you need to do or would you reccomend the whole kit with weights etc? Your V with the tracks and skis is AWESOME!!!!!
Old Feb 8, 2004 | 01:12 PM
chop's Avatar
what is the difference between the pink spring vs the stock spring? i dont want a high engagement point.what benefit does this spring give? i put the red spring in my 650 and didnt like the high engagment.i want a spring that will allow you to rock crawl.so i like a low rpm spring,so would it be better to stick with the stock spring?
Old Feb 8, 2004 | 01:14 PM
  #15
Quadfather's Avatar
With stock exhaust, a lot of people are running the EPI pink spring with two more spacers/shims.
The pink spring has a Zero stall (engagement) rate, as does the stock spring. The pink spring gives a higher shiftout. Adding the shims will slightly increase both.
Old Feb 8, 2004 | 03:29 PM
  #16
RIDEFORLIFE's Avatar
How do you like your DMC exhaust. I just added the FMF power bomb to mine. I have not ridden very hard yet, but it seems have a little more power. I have not checked out my plugs to see how close my jetting is. I did what the manuel said so I guess I am close to where I need to be. I think I will try new clutch springs next. Do you recommend pink or red? Please reply with any info.
Old Feb 8, 2004 | 04:59 PM
  #17
Quadfather's Avatar
Red spring has a stall rating of 37, compared to the stock, and the pink, with a stall rating of 0 (zero)
Drag racers seem to like a higher stall rating, it engages at a higher rpm, therefore having a less chance of wheelying out of the hole.
Old Feb 8, 2004 | 05:02 PM
  #18
I have just finished seaching ebay for a hard filter air box, and could not find. I also seached other sights aswell. Do you have any suggestions?
Old Feb 8, 2004 | 07:34 PM
  #19
jetratt's Avatar
I got my hardstyle set up from a local dealership. The website is www.hardstyleusa.com however it is not set up yet.
Old Feb 8, 2004 | 07:59 PM
  #20
Quadfather's Avatar
Hyperflow Kit-$109-ebay item # 2459258514
