650/700 hmf pipe and dg snorkel jetting
I have a dg snorkel and just purchased the hmf pipe half system and was wondering if the jetting recomendations of putting the rear jet in the front carb and replacing the rear with a 143 main jet / 3.5 turns out on air fule screw works well . I live at sea level but will be ridding in the mountains as well.It just seems like the hmf recomendations are a bit lean and also don't account for the snorkel I would appreciate any sugestions or combos others have tried .
thanks
p700
blackspring
26 inch mud lites/ c series rims
dg holeshot module
hmf half system
heavy spring in rear shock
dg snorkel
thanks
p700
blackspring
dg holeshot module
hmf half system
dg snorkel
moving the 142 jet to the front and replacing the rear with a 145 is a safe place to start. If it's a little lean then go to a 145 front 148 rear. Or just leave your stock jetting along and go with a dial-a-jet. Dial-a-Jet information
good luck
cart
BTW.........don't even fool with DYNOJET jet kits. The prairies are difficult to get tuned properly with DynoJet jets. Just forget they exist!!!
good luck
cart
cartman I put in a dynojet kit here a while back and your right it has run a little rich. I also read a little about them sence then. I ordered a 145 for the rear but was thinking of just leaveing the needles in. What your opion like black bear i live at sea level also. Macon ga.
hello cartman! you seem to know a little bit aboute jetting! i did the nyroc's mod, remove the snorckel
of the air box and jet to 142 front 145 rear and it seem very lean. im waiting bigger jet from order.
i am in quebec, about -15c , close to see level. any idea?
new in this forum. thank you.
mario.
mario.
mrtidy
Feb 3, 2016 05:00 PM
