Spark Plugs for P650?
Old Feb 8, 2004 | 07:46 AM
DaveK3131's Avatar
Default Spark Plugs for P650?
I was wondering if anyone tried different plugs in the 650...The book calls for NGK CR7E
Mine seems to foul out rather fast Thanks for any info
Old Feb 8, 2004 | 01:45 PM
chop's Avatar
if your fouling plugs (too black) then your jetted too rich.try droping down one jet size and see how that does.you may have to go down more than one size to get it right.hope this helps.
Old Feb 8, 2004 | 04:40 PM
STAKK's Avatar
Fouled plugs usually do mean too rich or you may have the infamous sticking choke situation, or even leaving it choked too long will do it, after you have got the bike running lean enough, going to a NGK CR8E which is one notch colder will lower the head temp's about 5 degree's..........but they will foul easier than the 7's if you are too rich
Old Feb 9, 2004 | 09:01 AM
p700wheelieman's Avatar
try running a cr7ek the k is dual electroid i run that plug in my yz426f and it works great also if you run it on choke a lot it will black out, that plug came standard on gsxr street bikes
Old Feb 9, 2004 | 05:55 PM
DaveK3131's Avatar
OK thanks for the info......I just installed my stronger choke springs so maybe that will help me out with fouling the plugs
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
