Spring thing for the V
Old Feb 14, 2004 | 12:50 PM
LUVMIKFX700's Avatar
Default Spring thing for the V
would someone explain to me how all the springs affect my v and where I can get them please keep it color coated.
Old Feb 14, 2004 | 01:13 PM
i run at altitudes from 4000-6000ft. and my v if heavily modified please help i need it to wheelie a little less
Old Feb 14, 2004 | 04:17 PM
flyingvforce's Avatar
the spring determines the amount of pressure to be applied to the belt in order to engage trans.
if u have stock spring there is not alot u can do
Old Feb 14, 2004 | 04:21 PM
try epi ind.com or thunderproducts.com or hpd or daltonindustries.com
Old Feb 14, 2004 | 05:01 PM
Quadfather's Avatar
If you are worried about wheelies of the start, you could install a spring with a higher stall rate. Call Dale at Dalton Industries. He'll answer all of your questions, and point you in the right direction.
Old Feb 14, 2004 | 07:17 PM
Jaybe's Avatar
Hey LUVMIKFX700, I run at about the same altitudes, sometimes a little higher. I run the EPI pink spring, but it has zero stall, not a good spring if you don't want to wheelie. Look for a spring that has a little stall in it...If you are like most, you may have to buy several to see what works best. What Mods do you have? I am curious about your jetting..
Old Feb 14, 2004 | 08:22 PM
well right now my quad is in the shop at alba will be for a few months there gatheing together numbers for a quote ill post when its done itll be over 800cc's by then.
Old Feb 14, 2004 | 11:22 PM
reconman2003's Avatar
does the v have a manual clutch?
Old Feb 14, 2004 | 11:35 PM
pulverized's Avatar
No, it's an automatic[img]i/expressions/face-icon-small-smile.gif[/img]
ghost civic
Jan 15, 2020 07:43 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
