turning p700 into a racer
Old Feb 19, 2004 | 12:41 PM
melvin's Avatar
Default turning p700 into a racer
anybody here have any suggestions for me. i'm going to be switching from a 400ex to a p700 this year. i'll be racing local xc races and need to know what mods to do first. i all ready know that the stock tires need changed, but besides that what should i do? and, are your quads still able to do the normal around the house chores? i still need it to plow snow, haul wood, and tow the gang mower. any suggestions are apprecated.
Old Feb 19, 2004 | 12:54 PM
newbeatle's Avatar
Click on PRAIRIEWRENCHES camera & check out his pics & mods... his is more race specific... mine gets used for nearly everything,
if you want to get started, a set of Elka front springs, don't remove the front rack, unless you make a strut to go across the rear rack bolts to support the tops of the front shock towers, by pass the belt trip switch, add the V Force reinforcing ring to the rear axel, teather kill swich, the right tires & wheels... your machine will be pretty competitive... add the new CDI when it comes out... your quad should be very competitive... after that, look at some of the motor mods & get your driving down, & you'll be leading the class in your area...
Old Feb 19, 2004 | 01:02 PM
SHOTGUN's Avatar
Don't mess around, call Mickey D, get an 800cc kit, (get in line) and kick some ****.
Old Feb 19, 2004 | 01:12 PM
melvin's Avatar
thanks for the replys. i already know that shocks are going to be replaced some time this year, its hard to go from laegers and elkas to stock ute. any info on opening up the air box? i heard talk about a napa hose, but is that all that you use, or does that connect to the air scoop?
Divergent12
Dec 30, 2017 08:33 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Backwoods_badass
Aug 2, 2015 10:40 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
