Runs Great when its.........................
Old Feb 28, 2004 | 12:42 AM
HavinSomeFun's Avatar
Default Runs Great when its.........................
Ok here we go, My '03 p650 runs a ton better when its cold. After it warms up it still runs good, just not near as good when its cold. This tells me it is running rich somewhere. Also when someone is riding behind me they say its rich.
The question is Change Main Jets? air /fuel adjustment? Shim the needle? What or where Should I start?
The only mod that would effect it is the exhaust mod. I am running stock jets, air filter etc.
Old Feb 28, 2004 | 12:54 AM
trailride's Avatar
Hey lets change your airfilter and snorkle and see what happens. Lets pull those carb heaters off also
Old Feb 28, 2004 | 01:12 AM
I am planning on the Napa Hose this weekend and ordering a filter sometime soon. I just hate waiting for the UPS truck. I wish I could just go and buy one!
Old Feb 28, 2004 | 03:19 AM
Customfabandweld's Avatar
Carb heaters?
Old Feb 28, 2004 | 07:15 AM
schl48's Avatar
ck your plugs that will tell you what you need to know. black is rich tan is good gery white is lean. rich add air or take away gas(smaller jets.)
Old Feb 28, 2004 | 07:18 AM
schl48's Avatar
carb heaters are a little hose that lets water from radiator run threw your carbs, to elimanate just bypass carbs with hose.
Old Feb 28, 2004 | 09:52 AM
roscoe69's Avatar
havensomefun
before you get into the part about pulling everything apart check the chokes.
Old Feb 28, 2004 | 11:12 AM
schl48's Avatar
now thats a great idea.
Old Feb 28, 2004 | 12:05 PM
hondabuster's Avatar
Sounds rich to me , check to see if the choke/enrichener is sticking. Heres an article on jetting and adjusting the carb.carb
Also check the air filter, it could be over oiled, or dirty.
Old Feb 28, 2004 | 12:44 PM
That is a great article on carbs and yet I have another question. If you shim the needle doest that make it richer or leaner. I am thinking richer. However, I remember being wrong once when I was a child.
