400ex axle on mojave
Old Feb 28, 2004 | 04:07 PM
juniorsmojave's Avatar
Default 400ex axle on mojave
i thought i read a post on here that a 400ex axle will fit on the mojave, but now i cant find any info on this. if it does fit how much wider is it, also wondering if it is a direct bolt on or if it requires more than just having the axle. maybe some other axle might fit. thank you.
Old Feb 29, 2004 | 02:34 PM
mahnster's Avatar
I havent heard that the axle does but i have heard of 400ex hubs fitting on the mojave.
Old Mar 15, 2004 | 09:31 AM
mojavekid13's Avatar
THe axle will not fit, and nither will the Hubs, THe only thing is a CARB from a 400ex
And as for hubs, hubs from a honda 200x 3-wheeler, will fit on your mojave, and let you run smaller rims
Old Mar 15, 2004 | 11:48 PM
toyaddict's Avatar
400ex hubs will fit on the mojave but you need to make a custom spacer to get them to fit correctly. The splines and shaft are perfect fit.
Old Mar 16, 2004 | 09:10 AM
YA but if you used honda 200x hubs there is now mods at all, Just a dirrect fit!
Old Mar 19, 2004 | 11:07 AM
JayBR's Avatar
FYI: Cannondale hubs will fit with no mods. Their alluminum and have the same bolt pattern as Honda
Theres a pic of the Mojave I'm working on at http://cannondaleriders.com/vbb/show...5&pagenumber=2 where you can see the hubs.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
