Bent axle on V--Need new one!
GE4x4, I would give Lonestar a call first. I have heard they do make an axle for the "V". I've found that several companies don't update there web sites on a regular basis. I WOULD check into exactly what their policy is if you bend one of their axles. Personally I wouldn't want to spend that kind of money and should I bend the axle their solution is just to re-bend it and send it back to ya.....then again, I've been told I'm anul retentive at times.
#18
Also have a axle sitting in the corner of the garage, if anyone is interested. Go with an RPM axle can't go wrong. They are a bit pricey but I think that it was worth it. Helped handling being 2+2. Also changes the left side to twin tappered bearings instead of the standard single ball bearing. Pretty sweet fit and set up were verry easy.
#20
