How big is TOO big ???
Old Mar 9, 2004 | 12:06 AM
bbertram's Avatar
Default How big is TOO big ???
****CURRENTLY DOWN****
hehe
PS: When I mention gears I should call them sprockets. That makes more sense.
Old Mar 9, 2004 | 08:43 AM
SHOTGUN's Avatar
If belt slippage is a problem. call dalton get their heavest weights.
Old Mar 9, 2004 | 08:55 AM
kwackermann's Avatar
Gears and chains instead of clutches and a belt? Wmothing is gonna break off somewhere, like the tranny output shaft. STAND CLEAR!!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 9, 2004 | 09:40 AM
newbeatle's Avatar
Realisticly I'll do the 33" tires ... they are about 1/3 the price of the ultra cool 37" Rice & Canes ... 10" of tool steel, ultra light wheel spacers of my design, the wheels will only have about 1" of back spacing, & I'll at least have some steering, but obviously not lock to lock steering ... It is my intent that the tires will sit fully outside of the fenders & floor boards... the tire & wheel combos in the 33" size weigh less than 50 lbs... no more than a typical 28" mud tire, mounted ... the black secondary spring & a spare belt ( I currently have a new 360 belt installed ) plus the primary spring I pick that works the best for those specific tires, will be the extent of the CVT mods... low range & a little easy on the throttle, & they should work ... I intend to compete in the SRA class, as well as the open class... I wish I could talk Dyna out of a CDI for the race, but even if they are released by then, I'll have any spare jing tied up in new tires & wheels, & the trip down... ( 900 miles, one way )
Old Mar 9, 2004 | 10:39 AM
  #15
EasterEgg's Avatar
How do they determine what goes in the small mud hole for the non lifted quads?
I think 25" paddles all the way around would be more fun. Just like a real mud bogger get up on top and fly across.
I've seen a Zilla with paddles run within 1 second of 4x4's in a 150 ft mud pit.
Old Mar 9, 2004 | 11:28 AM
  #16
newbeatle's Avatar
E.E. that is one of the sets of tires I'm taking.... SSSHHHH... however, in reality, the paddles will only work if there is none ( or at least minimal )water on top of the mud... so now that the cat's out of the bag, I'll have the 25" paddles, my regular 28" Zilla's, & the 33" tractor treads...
Old Mar 9, 2004 | 01:06 PM
  #17
EasterEgg's Avatar
Oooooooppppppppsssss !!!!! [img]i/expressions/face-icon-small-blush.gif[/img]
Old Mar 9, 2004 | 05:49 PM
  #18
alltoys's Avatar
Tall and narrow is the order of the day!! Have you ever seen a model T stuck they used to go through much more stuff than a 4x4 of today will do!! Tall, narrow with big lugs there is a set of tires called AG tires that are would work excellent. With a big bore kit it will motor across the mud. I use 27 inch Outlaws with lots of wheel spin almost impossible to stop good luck at the Nationals let us now how it turned out.
Old Mar 9, 2004 | 05:57 PM
  #19
newbeatle's Avatar
As bad as I'd like to run the 37" Rice & Canes, they won't guarentee that I'd have them in time, so it looks like I'll have to do the 33"...
But...you can check them out on the Firestone site
http://www.firestoneag.com/databook/...st.asp?ref=109
DROOL... DROOL...DROOL....
Old Mar 9, 2004 | 06:14 PM
  #20
bbertram's Avatar
HOLY CRAP!!!! Look at those tires!!! Amazing, you would kill everyone with those tall guys.
