What other oil filter fits a P650?
A motorcycle enthusiast posted these numbers. These all have the same threads and o-ring. They fit the 650 as far as I know. The 650 also has pressure specs smack dab in the middle of auto oil presure specs, so ther is nothing wrong with using an auto filter. Some of these filters do not have the thread clearance needed for a grizzly 660 of a P400. I know from trial and error, so be careful thinking that one filter will fit all atv's. I think the P400 filter will fit a majority of ATV's, but the filters from some ATVs will not fit the P400. The 650 does not need any clearance, so I would guess that a majority if not all filters with that same thread and o-ring will fit it. If you go down the oil filter isle, you may find more. There are 2 different thread specs for the really small filters. You will find about 1/3rd of the smallest filters will proly work. You probably can take a caliper into the store and measure the threads. As far as I remember there are no filters with that same thread diameter that do not fit the 650.
I have tried a few. They work. I have heard not to use the fram due to paper end caps or something getting fibers in the oil. I have used an STP SMO-017. I am gonna just use amsoil in the future.
Motorcycle-Specific Filters - (About 2.5 to 3 inches long)
Purolator Motorcycle ML16817 about $6.00
NAPA Gold 1358, Carquest 85358, WIX 51358 about $7 to $8
AC Delco PF2135 about $10
FRAM PH6017A about $7
Automobile Filters - (About 3.5 inches long - fit reference 1994 Mazda MX-3, V-6 Engine)
Mobil 1 M1-110 about $10
Bosch 3323 about $5
Purolator Pure One L14620 about $6
NAPA Gold 1356, Carquest 85356, WIX 51356 about $6
Deutsch D-370 about $4
AC Delco PF-2057 about $6
Motorcraft Long Life FL-821 about $4
STP S-02867 about $3
FRAM, Castrol, Penske 7317 about $3
Automobile Filters - (About 2.5 inches long - fit reference Mazda RX-7 and Miata)
Bosch 3300 about $5
NAPA Gold 1365 about $6
Purolator L14622 about $5
AC Delco PF1237 about $6
STP S-02876 about $3
FRAM PH6607 about $3
Technical Fitment Specification
20 X 1.5mm threads, gasket diameter approximately 2.3 inches, O.D. approx. 2.75 inches, length approximately 2.5 to 3.5 inches.
Bosch 3323 about $5
Bosch 3300 about $5
Customer Service #1
05-15-2020 08:46 AM
Steeldon
09-09-2015 09:38 AM
