installed skid plate..
Old Apr 15, 2004 | 08:52 PM
BudO's Avatar
Default installed skid plate..
Just to let you know I've just installed Ricochet skid plate and CV/swingarm.
While installing the swingarm plate I've lifted the bike and I've noticed a small squeal coming from the swingarm spinning the tire, this sqeal disappear spinning it faster , seems like rubbing(gneeeeeek) somewhere inside and is not plate or tire related, any hints?
BudO here
Old Apr 17, 2004 | 10:50 AM
BudO's Avatar
any hints about the noise ,I'm a little paranoic...
Old Apr 17, 2004 | 11:27 AM
NovaKaw650's Avatar
Make sure the fluid is up to the top. The only things that could squeak would be the u-joints or a dry seal rubbing on a metal shaft.
Does the swingarm skidplate cover the entire swingarm, or just that portion already covered by the factory plate?
Old Apr 17, 2004 | 11:31 AM
Nightryder888's Avatar
mine use to do that but only on a cold start, i took it as the seals for the axle not being lubed up enough when you first start the machine. it has quit doing it for the past 400 or so miles.
Old Apr 19, 2004 | 10:08 AM
BudO's Avatar
Thanks Guys.
I'll check fluid in the swingarm.
Old Apr 26, 2004 | 11:31 AM
BudO's Avatar
Scott,
I've forgot to say the swingarm plate cover it all.
budO
Old Apr 26, 2004 | 02:37 PM
TTM360's Avatar
Hey BodO
Where du you buy your mods on the net ? have you try to buy something from US to EU ? ( From US to Italy )
[img]i/expressions/face-icon-small-smile.gif[/img]
T. M
Old Apr 26, 2004 | 10:51 PM
BudO's Avatar
TTm,
I always buy in the States ,you can find everything you want on the net in a minute ,and have it at your door in a week at worst..
In Italy you start phone calling every dealer all day long just to find out they have no idea what you are talkin' about, and if you are lucky enough to find what you need it cost almost double than in the states.
so I prefer to go the US way.
God bless america
ReconBayou
Oct 31, 2022 05:37 PM
Oct 10, 2015 10:20 AM
2many2ride
Sep 27, 2015 04:35 AM
toonces
Sep 5, 2015 01:14 PM
