Put the 750 to the test!
Old Apr 29, 2004 | 10:16 PM
  #21
Bocephus01's Avatar
Default Put the 750 to the test!
All this talk about big bore kits and 80mph is making me want one,the wife will love that. I am gonna be divorced before I know it.[img]i/expressions/face-icon-small-wink.gif[/img] BTW wildwill very nice bike you got there.
Old Apr 29, 2004 | 10:55 PM
  #22
bbertram's Avatar
I really want to know how your clutch affects acceleration.
I think the Praire is geared a little lower but the 25" tires make up for that lower gearing. The 25" stockers fit on the v-force but will ballon out and hit the foot pegs. I tried it, look at my pictures.
Also the CDI increases the Praire to 33 degree timing across the board, this is higher than the V-Force stock. The V-Force runs at 28 degree across the board I believe. Add a degree key and you should get there faster. Also the CDI on the Praire increases the rev limiter while the V-Force is stuck at a lower RPM and thus less speed.
These things all add up.
Old Apr 30, 2004 | 12:02 AM
  #23
sincityduner's Avatar
I have Mickey D's CDI which has a rev limit of 10000, the problem I have is I seem run out of clutch before I run out of motor, but I really don't have enough asphalt around here to really found out what my limit is.We are going to armagosa sand dunes tomorrow,there is an old highway near by I will see if I can find out.
Old Apr 30, 2004 | 10:47 AM
  #24
alltoys's Avatar
Wildwill,
Use one shim with Daltons face plate, the shim should add to 0.050 inchs if so use one instead of two for the OEM face plate.
Sincity
It takes a good shot of HP to go over 85 mph plus gearing and tires. Not to mention a very good ignition one that will hold determined spark over 10,000 rpm. Dyna has been gracious to help me attain these goals next spring I will try another run to break 100 mph soon as I heal up well enough, LOL. I must also say that the quad is to short for high speed runs the quad will under go a streching by at least 12 inchs this fall. It should help for drag racing as well. There maybe a chance later on that Dyna will build a multi function cdi for the V so far there is testing being done on the V with excellent results.
Old Apr 30, 2004 | 10:50 AM
  #25
bbertram's Avatar
WOOT, good news. Now do I delay my V build up or go ahead with what I had planned? hmmmm
Old Apr 30, 2004 | 11:12 AM
  #26
MickeyDunlap's Avatar
Skat Trax had the 785-v up to 90.6 mph but it has a chain drive and my CDI.
Old Apr 30, 2004 | 11:17 AM
  #27
bbertram's Avatar
Would love to see that chain drive setup. Would be very unique.
Old Apr 30, 2004 | 11:23 AM
  #28
Thats what I'm going to do with mine just because I want it to handle better at the speed it will be going.
Old Apr 30, 2004 | 11:29 AM
  #29
bbertram's Avatar
Get us pictures!
Old Apr 30, 2004 | 11:34 AM
  #30
SHOTGUN's Avatar
Are you going for the 100 mark??[img]i/expressions/face-icon-small-shocked.gif[/img]
