vforce 800 and micks cdi rev limit ?
Old May 5, 2004 | 10:02 AM
sincityduner's Avatar
Default vforce 800 and micks cdi rev limit ?
good thinking new beatle, i forgot about that, i had the same problem, had to rerought the vent hose up by the handlebars and put a little K&N filter on it, and run the oil level right at the bottom of the dipstick which is 1.9 liters
Old May 5, 2004 | 10:31 AM
fullthrottlevforce800's Avatar
already done that vented up by handlebars no oil problem now . like i said either hitting rev limiter or run out of clutch
Old May 5, 2004 | 11:44 AM
MickeyDunlap's Avatar
There is no way you are hitting the re-limiter unless it's a bad box. I'm just now starting to test are 800 G-Force stuff now but I dont even have a box myself to test, anyone want to seed theirs back?
Old May 5, 2004 | 12:12 PM
i'll seed mine back if its bad box. mickey u think i could be just running out of clutch .cause it seems wants to go faster just like ignition cutting out or clutch holding it back like it wants to rev more just wont though
Old May 5, 2004 | 12:26 PM
  #15
bbertram's Avatar
It might be hard to tell the difference between running out of clutch and bouncing off the RPM limiter if your new to this.
What you can do is put the quad in neutral, make sure its warmed up. Rev it up, bounce it off the limiter to hear what it sounds like. Then you will be able to distinguish between running out of clutch or bouncing off the limiter.
I think your running out of clutch. What size of tires are you running in the rear? 22" stockers? You could try 24" tires, it may look weird but you would gain some more top end.
Though thinking about all of this, running out of clutch would not stop you from gaining speed. I think you have the HP to make the quad rev even higher after the clutch runs out but you would gain speed slowly and it may sound different. I think this is what is happening.
Old May 5, 2004 | 12:57 PM
  #16
i guess im gonna have to put tach on it see what my rpms are . no im not new to this but like u said hard to distinguish between rev limiter and runnin out of clutch .my guess is rev limiter though cause sounds the same as when u are in reverse when ignition cutting out .could also try old cdi to see if bad box . thats case that rots i dont even have 10 miles on it sense i did 800 kit and cdi must been bad box from start then but i dont believe it . i still think just hitting rev limiter when it does it im at some wicked rpms . even had me dealer try ride it and he also believe its hitting a rev limiter he said
Old May 5, 2004 | 01:01 PM
  #17
wildwill's Avatar
Maybe could be jetting? Kill the motor when it starts to miss and pull your plugs to check. Maybe you may rich or lean? When I first got mine running it would hit the rev limiter at 66mph and was lean. After jetting proper it never hit the rev limiter and ran up to 74mph. That was with the stock CDI.
Just a thought[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 5, 2004 | 07:43 PM
  #18
fullthrottle, FYI it takes me about a quarter of a mile to get my bike into the 8500rpm range, I don't believe there is any way you could hit the rev limiter in 400 feet like you were saying, so I think your in the right track, try changing back to the stock box to prove if you have a bad one if that doesn't work then maybe its jetting, I know I'm stating the obvious, but just trying to help.
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
