Go here for pictures of Fast Flexx bars on V-Force
Found these while checking out another forum......GOOD pictures:
http://community.webshots.com/album/139993376vfQatV
when you post a message look up in the top left just under message text, click on the button that says http and a small window will pop up that you put in the url and them another window pops up and you can enter any text you want to call it. easy
MnFriesen, not sure if you're asking about the bars or the brake lines but just in case....... the Galfer SS brake lines run about $95 not including the aluminum brake line holders. You really could zip-tie the brake lines but I thought the aluminum doohickies looked better (I believe they ran me around $28 per set). Just as a note, my brake lines as ordered from Galfer (other companies make SS brake lines) are +3" lines. I first ordered their "stock" length lines and found them WAY to tight for me after you secure them and all. Others have experienced the same with there "V's" and Galfer's "stock" length lines. They also carry a +2" as a standard stocking item but being I wanted to run my lines through the aluminum holders and wanted no binding throughout the entire range of motion the A-arms may go through I had Galfer make me the +3". They are great people to deal with.
Originally posted by: Mark82ndABN
BigOne, thanks.
I love the Galfer brake lines. You will lose that "spongy" feeling you find with the stock lines. Much, much better feel.....and they look cool too.
BigOne, thanks.
ss brake lines
are theese what i need. i see they have the 2 lines and 3 lines what do i need??
i would like to get all the lines from the brake lever down to the calipers. i would think it the 3 lines.
were did you get yours??
