Where is the neutral relay located on a Prairie?
Mine only starts when the brakes are applied in neutral, so I think it may be bad? I looked in the manual but couldn't find it, only in the wiring diagram.
Thanks[img]i/expressions/face-icon-small-happy.gif[/img]
It is next to the CDI.
The brake starter relay looks like the exact same kind of relay, but it is between the heavy crossbar and the seat catch crossbar. I think those are the only two frame crossbars that are on top and readily visible when the seat is off.
your sending unit is located near your rear motor mount bolts on the left side looking from the rear. look on page 16-3 in the electrical section at the bottom.
_____________
02 650p
nyroc muffler
super snorkle
155f/157.5r jets
needles shimmed .033
3 1/2 turns on the pilots
dynatek cdi
epi black
700p drive spring
warn 2000
plow
_____________
02 650p
nyroc muffler
super snorkle
155f/157.5r jets
dynatek cdi
epi black
700p drive spring
warn 2000
plow
nyroc
it was my neutral starter circuit relay. i swaped the brake to neutral and it worked. i do have a manual i just couldnt find it, i must have flipped over that page.
wildwill
i checked ronayers and the neutral strater relay ran about 15 bucks
______________
02 650p
nyroc muffler
super snorkle
155f/157.5r jets
needles shimed .033
dynatek cdi
epi black
700p drive spring
warn 2000
plow
just got my bighorns
wildwill
______________
02 650p
nyroc muffler
super snorkle
155f/157.5r jets
needles shimed .033
dynatek cdi
epi black
700p drive spring
warn 2000
plow
Another guy just hit his relay with a screwdriver and it started working.
If your neutral light works, forget looking at the neutral sensor. This happens a lot. Most likely it's just the relay.
Thanks guys!
The neutral light still works so it most be the relay. I think a good couple of wacks from a screwdriver can't hurt[img]i/expressions/face-icon-small-wink.gif[/img]
just for your information.
the screwdriver wipping that i gave to the neutral relay worked. he ha
________________
02 650p
nyroc muffler
super snorkle
155f/157.5r jets
dynatek cdi
epi black
700p drive spring
warn 2000
plow
________________
02 650p
nyroc muffler
super snorkle
155f/157.5r jets
dynatek cdi
epi black
700p drive spring
warn 2000
plow
