Prairie 650/700 twist throttle
I have their cable and twist throttle and like it! I think the cable was $34 and the throttle $21. You will have to hook a toggle switch to your old toggle off the thumb throttle for the 2wd/4wd. Just snip the wires and tie in. They may have a whole kit with toggle available by now, they mentioned it when I got mine 2 months ago. There is a picture on my page of my setup.
It does take some time to get use to, but I like it better than the thumb. I don't get thumb cramps anymore.LOL
I got you on NATION... but here was my reply...I found it very easy to cut the proper sized opening in my handlebar shroud with a dremel, & originaly mounted it there... then I made a control panel for accesories on my filter box cover ( this one is temporary, I'll be using one from Cabella's ( a marine panel ), shortly, now the 4 X 4 switch is mounted there, after I had removed the handle bar plastic cover...
I've had mine on for about a year... it is a Motion Pro, for a 400 Prairie... It goes right on, with no mods, however doesn't have the switch mount... I was told that Motion Pro would be offering one with the switch mount for the 650 / 700's, anytime, last year, when I ordered mine, so I'd expect that they have that kit out by now ( one year later )
MeadowlarkFarm
Nov 27, 2019 08:40 PM
