Muzzy pipe jetting kfx 700
you got to open up that air box and i would jet a little more, somewhere in the 158,160 range this is with more air in of course.add a second snorkle to that thing[img]i/expressions/face-icon-small-smile.gif[/img] and if you do you should shim the needles.
have you changed your clucth spring yet?? it goes hand in hand with the pipe. you are moving the peak hp up a little and a stiffer spring is needed to take advantage of this
#15
Originally posted by: BossMann
I have the Dalton kit installed,weights,spring,face plate. What does the shims do. Here in Ga we get a dust finer than baby powder.I wanted to stay away fron air box mods but if thats what it takes I will mod that sucker. Thanks for the replies and info
check this site out
good site for install of differnt things
mrtidy
02-03-2016 05:00 PM
