Acticat 400dvx VS. kfx 400
Old May 13, 2004 | 11:52 PM
Kawasakiman50's Avatar
Default Acticat 400dvx VS. kfx 400
What is the better machine all around the kfx400 or the arcticat 400 dvx? Is there really much difference. The only difference I've seen is the the lubercation the Kawaski is wet sump and the arcticat is dry sump. Does this really make much difference. I've riden the arctic cat it seemed that it was geared pretty high. What one is faster? I have a 01 praire 300, sux because of all time 4x4. I want a sport quad hopefully a 400 class what is the fastest 400 class atv Any info will hope
Old May 14, 2004 | 02:10 AM
oldyeller's Avatar
The kawi has the dry sump oiling system as well.The kawi,Suzuki Z400 and the DVX are all the same mechanically.The 04 DVX already has the late 04 Suzuki updates though.These include a different chain adjustment system on the rear swingarm and a two piece rear sub frame with a removable grab bar and the muffler outlet is supposed to be a little bigger.The biggest difference is the plastic and seat.The DVX's fenders are removable and you can get different coloured fenders to create a unique look.The seat is a little narrower to allow easy movement on the bike.There should be no difference in speed on any of these 3 machines its more a matter of personal preference which one you get.
Old May 14, 2004 | 07:06 PM
Thanks for the info your right now that i look at the speck sheets i was the thinking about the v-force that has a wet sump lubercation thanks again the info is very help full is the v-force faster though
Old May 14, 2004 | 09:12 PM
bbertram's Avatar
Yes the V-Force is faster.
sam
Dec 3, 2003 09:52 PM
ATVMadness
Sport Quads
41
Aug 25, 2003 11:33 PM
