tech help please
Old May 17, 2004 | 01:26 AM
Crawdaddy's Avatar
Default tech help please
I need help with my father in-laws quad it is a 2000 kawasaki 300 auto 2x4. The problem is that when we started it today it would not idle so i turned up the idle, then it started and idled good but when you put it in gear it would die. It will not move at all as soon as you put it gear and hit the throttle it would die.I did not have a chance to check it out just wondered if yall could give me some tips on what to check out. Sorry about the length. Thanks phillip
Old May 17, 2004 | 01:27 AM
MnFriesen's Avatar
is it jetted right?
Old May 17, 2004 | 01:29 AM
scrambler123's Avatar
Check the condition of the air filter, check to make sure the carb boots are sealed tight, check the plug.
Old May 17, 2004 | 01:41 AM
Crawdaddy's Avatar
Originally posted by: MnFriesen
is it jetted right?
It is a totally stock bike, It was working fine about 2 weeks ago when I rode it.
Old May 17, 2004 | 02:58 AM
MnFriesen's Avatar
what kind of terrain has it been subjected too since you rode it?
Old May 17, 2004 | 11:09 PM
Crawdaddy's Avatar
sittin in the shed it is mostly just rode in the yard
Old May 18, 2004 | 02:56 AM
MURDR's Avatar
Check the spark plug. if that is not it check the carb for any build up. After checking those two things, if the problem is occuring then it could be your jetting. Also check your choke lever it may be stuck.
speedbuff
13
Nov 11, 2020 10:16 AM
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
rgjackson
Sep 17, 2015 11:21 AM
blueandy88
Aug 31, 2015 12:42 PM
