first attempt..
Old Jun 15, 2004 | 11:12 AM
Metallikev's Avatar
Default first attempt..
aye,im heading to Home depot now...I hope they have those screws..im looking for both 4x14 and 4x16 with washers just to make sure..its kind of a long drive for me so id rather spend a few extra bux while im there then have to drive back...thanks for the tips guys..keep em comin..lol
Old Jun 15, 2004 | 05:44 PM
Metallikev's Avatar
well,heres my update..that was a lesson in frustration..3 screws on each one were a snap..1 screw on each stripped out on contact..WTF gives with that..dumbass engineers,must be a ploy they use to get you to take it to a dealer..one of these days when ive got lotsa time and its a helluva lot cooler out(91 today) Ill try it again..only thing is ill have to take the carbs off to remove those stinking stripped screws..needless to say that NOPE it didnt get done....and Im not to happy about it.. =(
Old Jun 15, 2004 | 06:06 PM
BUDXXX's Avatar
You know, every Kawasaki I have ever had, quite a few, have all had the soft/stripped float bowl screw problem.....
Old Jun 15, 2004 | 06:10 PM
Just4Kicks's Avatar
Been there, done that. It always seems to be the last screw somehow. I am one of those damn engineers too...I only design buildings though so don't shoot me. Did you get that screw extractor set?
Old Jun 15, 2004 | 07:42 PM
  #15
Nightryder888's Avatar
i tried the screw extractor on mine but that just made it worse, the screws are WAY to weak and in there WAY to tight. a good set of vice grips did it for me
Old Jun 15, 2004 | 08:28 PM
  #16
deerchooper's Avatar
just take some plyers or vice grips, and latch onto them. they will come loose. i had the same problem. i didnt remove the carbs. i bet the top left on the rear, bottom right on the front carb is the ones that are stripped.
_____________________
02 650p
nyroc muffler
super snorkle
147.5f/152.5r jets
.033 on needles
dynatek cdi
water wetter
plow
receiver system
warn 2000lb
bighorn's
dayco 2017
to come, air/fuel ratio gauge
home made muffler
Old Jun 15, 2004 | 09:15 PM
  #17
Metallikev's Avatar
actually its the ,rear carb bottom right and front carb bottom left..all the other screws came off so easy it wasnt funny..those last two..ARRRGGG..i was mad =)....I guess when I get the chance I will get a pair of needle nose vice grips and try..any thing else means pulling the carbs out and ,damn,i dont wanna do that...I did pick up a screw extractor but figured that would only make things worse...Ive got a buddy with a well stocked garge whos gonna let me use his stuff, he also does his own mods on a YF400 dirt bike so he's got some experiance in this
Old Jun 15, 2004 | 09:47 PM
  #18
hellyeh's Avatar
Eternal Rider
Building A Runway To Hell & Back!
The engine is the heart of an airplane, but the pilot is its soul. ~Walter Raleigh
metallikev i know your frustration brother. use a center punch on the head of the screw. place it in the center of the screw and give it a couple "light taps",remember the carbs are aluminum, and try to remove the screws.hope it works for you, worked for me.
Old Jun 15, 2004 | 09:52 PM
  #19
trailride's Avatar
Kliehn Crimpers from lowes. Or long nosed Dykes , will dig into the screw for grip. This will remove your screws. Trust me it works
Old Jun 16, 2004 | 11:17 AM
  #20
Metallikev's Avatar
thanks for the tip trailride..ill give that a shot here soon...im still a little disgusted tho..=)
