(??CRAP OR NOT) LTZ400 Z400 KFX400 NEW Upgrade! 3+ HP in 5 minutes!
Old Jun 29, 2004 | 05:39 PM
Mark2203's Avatar
Default (??CRAP OR NOT) LTZ400 Z400 KFX400 NEW Upgrade! 3+ HP in 5 minutes!
Depending on where you're riding, sometimes they do and sometimes they don't recommend just the intake cam. You may want to verify it with hotcams.
Old Jun 29, 2004 | 08:06 PM
MURDR's Avatar
But, they added power and is defanitly faster than stock cams.?
Old Jun 29, 2004 | 08:35 PM
Mark2203's Avatar
It's significantly faster, but it may have something to do with the fact that I ported, upgraded the carb and added the DRZE gaskets at the same time I did the cams. I have heard that you loose low end if you do both cams at the same time and nothing else. Try at least doing the gaskets and the valve springs at the same time. It's a pretty cheap addition (~$100-$150). The carb later (~$400) and porting (~$250) when you can afford it.
ultangler
Nov 30, 2024 01:35 AM
IMLN
Sep 28, 2015 03:32 PM
Sw00p
Sep 24, 2015 02:50 PM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
