drowned kfx400
Old Aug 13, 2004 | 12:40 AM
BeastMan's Avatar
Default drowned kfx400
here is everything that has been done so far:
4 gallons of oil ran though it
carb torn all the way down and cleaned and new seals
spark plug out and turned it over meany times to blow it all out, its just letting out air now.
new spark plug
at this time there is no oil filter in it cause i have been changing it so often.(does this matter?)
i have no air filter on right now(does this matter until i get it running?)
What else can i possible do to fix this problem?
Also when i try to start it it backfires badly, but trys to start but it cant
please help
(Also posted in suz forum)
Old Aug 13, 2004 | 02:24 AM
BeastMan's Avatar
o this is after drowning it out in a nasty pond that i shouldnt have been in. Anyone know anything b4 i take it to the dealer and get ( know without vasioline) 60$ an hour is outragious for labor,
Old Aug 13, 2004 | 04:24 AM
96lapiscoupe's Avatar
Try some starter fluid/ether. Just a small shot of it at the throat of the carb while you are cranking it.
Old Aug 13, 2004 | 01:07 PM
JoeMillionare's Avatar
You're gonna want to check compression. If the engine was running when it
inhaled water, you probably hydraulically locked the engine.
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
Jul 29, 2015 01:24 AM
mpcop077
Jun 10, 2015 08:30 PM
MuddyWater
Dec 8, 2002 06:36 PM
