Help! KEBC actuator motor keeps trying to come on even with key turned off!
Old Nov 12, 2004 | 04:52 PM
  #21
MikeyBoyesq's Avatar
Default Help! KEBC actuator motor keeps trying to come on even with key turned off!
Your problem is most likely the controller located under your seat. NOTE: The CDI (aka igniter) is also located under your seat, however the cdi is different from the controller. It turns out that my controller was faulty and was causing my KEBC actuator to continue to "reset" about every 5 seconds forever and ever (until I pulled the fuse out). It souns like your controller is bad too...I think I paid about $200 or so for my controller.
Good luck and happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 12, 2004 | 04:55 PM
  #22
2005BF750's Avatar
ah, thanks. I'm under warranty so it should be covered I hope.
Old May 17, 2009 | 03:15 PM
  #23
DRIZZLE's Avatar
I know this is a thread from the past but this is a problem that I currently need a little help with. I have tried everything I can think of to solve this KEBC reset buzz noise that happens about every 5-6 sec even with the key out. I am wondering if anyone has a used controller to purchase or if there is something I have overlooked to correct this without replacing the controller.
bzdok1234
30
Feb 23, 2016 01:55 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
