Drag Racing a V force
Old Aug 31, 2004 | 02:22 PM
BigWaynester's Avatar
Default Drag Racing a V force
LAst weekend at SilverLake I was tearing up the drag strip on my DS. I tried to get my buddy on his V to see how he would do. He said no, so I got on it. Going from a clutch to an auto for drags was not easy for me. What is the best way to get a good hole shot on a V ?
Old Aug 31, 2004 | 02:26 PM
LEP7MM's Avatar
Rev it until you feel the clutch engage with the brakes on. Then drop the hammer and hold on. Keep your weight forward over the bars. The front likes to come up on the V.
Old Aug 31, 2004 | 03:58 PM
hipsi's Avatar
I prefer to stab the throttle from an idle if the traction is real good. This seems to spin the tires a little more reducing the amount the front end comes up. If its real loose I will bring the rpms up until the quas is just starting to move and hold it with the front brake.
How do you get on the drag strip at Silver Lake? I will be up there next Thursday and would like to run my V if possible.
Old Aug 31, 2004 | 04:04 PM
Heathen's Avatar
It's just a straight away and anyone willing to run just pull up to the line. They drag in
different locations depending on the terrain and wether it's flooded or not. I'm gonna go the weekend after Labor day.
Old Aug 31, 2004 | 11:02 PM
SANDMAN430's Avatar
i know some guys are pretty good at it and some arent.
Old Aug 31, 2004 | 11:06 PM
Heathen's Avatar
It takes some getting used to.
Old Sep 1, 2004 | 12:11 AM
I totally sucked at it, I only did it 2 or 3 times, I got roosted on so bad I wasn't going to try it any more. Do you put on both front and rear breaks and break torque it? or just the front? Just nailing it didn't work for me. remember this is in sand, not dirt.
Old Sep 1, 2004 | 12:33 AM
BeastMan's Avatar
is there a place i can go to, to see if there are any places i can drag an atv in south texas?
Old Sep 1, 2004 | 09:41 AM
SANDMAN430's Avatar
don't the cvt engage at higher rpm with different weights seems that is what it would take for a ture drag -v, seems that is what they do with the snow machines.
Old Sep 1, 2004 | 12:09 PM
Heathen's Avatar
Yeh, I usually use both front and rear brakes. I shift my weight (235lbs) to the front and hammer down. Once the front end is down, I sit back and go.
