Brute Force Oil Filter which Fram?
Old Sep 5, 2004 | 03:06 PM
colmac's Avatar
Default Brute Force Oil Filter which Fram?
If you are using a Fram replacement could you please post the part number? I thought someone had posted some time back but I cant find it in a search. Please only post if you are currently USING a fram replacement in your BF. I dont want to chance, "well, the VForce *should* work", Thanks for your time
Old Sep 5, 2004 | 03:10 PM
BigOne's Avatar
Good luck with your fram filter.
Ever take one apart?
Old Sep 5, 2004 | 03:20 PM
colmac's Avatar
no, never taken one apart. Used them for many years and never had a problem. I change em when I change the oil and I change the oil when it starts to change color. maybe a waste but I have cars with 200k+ miles on them and the engines run/perform great.
Old Sep 5, 2004 | 03:57 PM
mikeames's Avatar
I think there's a link to some good info about oil filters on NYROC's sight (search Google "nyroc"). There was a list of most of the available filters that were of similar size and some other great info.... I've been using automotive filters with great success four about $4 each. Don't remember the numbers right off hand, but I'm pretty sure the link was on NYROCs sight.
Old Sep 5, 2004 | 04:03 PM
bmj67's Avatar
from what ive read fram is the worst oil filter you can buy for any machine. the end caps of the filters are made of cardboard unlike all others which use tin. heres a page that has a picture of the fram that was cut open you can see for yourself.
fram filter cut open
and heres a page that has an oil filter comparison of a few popular brands
Old Sep 5, 2004 | 07:05 PM
colmac's Avatar
Wow those links have convinced me. I guess the only thing that has been saving me it I change my oil and filters very often. I am amazed at the size of the filter of the Napa.
Old Sep 5, 2004 | 07:16 PM
jhmach's Avatar
fram cost a lot of guys some racing engines last year in v-8s they changed the filtering media and they would not flow thicker oil good and would it kill the bearings bad deal for a lot of people
Old Sep 6, 2004 | 08:53 PM
STAKK's Avatar
I use OEM filter's........Why? Auto filter's will fit, but have different flow rates than motorcycle filters and the bypass valves also work at different pressure's....You may be fine, But in the long run, you may have trouble with flow to the top end of the motor, i won't chance it.........
Old Sep 6, 2004 | 10:41 PM
tencubed's Avatar
Being retired is a hoot!
Danny:
Do you have the info on the difference in the flow rates and the pressures at which the valves function? A motorcycle mechanic told a friend of mine this same thing but offered no documentation. I have been using OEM as well because of questions regarding these issues. I have been unable to locate any numbers to prove or disprove the differance.
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
ylomnstr
Sep 4, 2015 05:02 PM
