first oil change, valve adjusment p700,when to?
Old Sep 9, 2004 | 11:28 PM
cookerwon's Avatar
Default first oil change, valve adjusment p700,when to?
what mileage should i first change my engine oil? what kind of oil to use and what weight? filter? basically the first check up on everthing and what to check..........thanks in advance..........oh and where do i get the black spring for the secondary, i believe?
Old Sep 9, 2004 | 11:43 PM
rivermud's Avatar
From the book, oil change is after 10 hrs or 60 miles, then evry 90days or 1100 miles. Oil is up to you but recomended is sae 5w-30, 10w-40, 10w-50, 20w-40 or 20w-50 grade API SF or SG. API SH or SJ with JASO MA . Valve adjustment is after every year of use. You get the black spring from epi (Erlandsonperformance.com)
donintennessee
Jan 8, 2021 12:40 PM
Divergent12
Dec 30, 2017 08:33 PM
Ronk407NY
Feb 13, 2016 11:05 AM
KSJOHN
Aug 30, 2015 08:15 AM
yambam13
Jul 4, 2015 01:49 PM
