Mojave piston ring problem
Old Sep 12, 2004 | 07:55 PM
Chris142's Avatar
Default Mojave piston ring problem
My Mo has been consuming large quantities of oil. It also fills the airbox up with oil and I have to pull the drain plug often.
So I pulled the top end down.
The rings are within specs. Specs being .008-.014 for the top 2 rings and .008-.028 for the oil rings. My specs are .009 for the top2 and .024 for the oil rings.
The oil rings seem to have lost their tension. They will fall down the cyl.
What causes this?
My intake camshaft is flat. Gotta replace it and the follower.
Cyl looks fine, even still has the hone marks. Gonna hone it and install new rings anyway.
I also plan on removing the stock airbox disaster and hanging an airfilter off the carb. Any problems with doing this?
Old Sep 12, 2004 | 09:59 PM
rolsmojave3's Avatar
no not a problem in doing this adds a lot of power just be sure to rejet
go to kawieriders .com with out that space between the s and .
Captjay
Jul 23, 2015 12:33 PM
xbin87116
Jul 13, 2015 02:10 PM
clsharky
Jul 13, 2015 02:07 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
