bayou300 backfiring thru carb???
Old Nov 16, 2004 | 11:37 AM
xrracer36's Avatar
Default bayou300 backfiring thru carb???
my dad just rebuilt a toasted kawi bayou300 for someone, and the kawi shop reassembled top end for us when they ordered parts, cuz they already had bottom end to clean out chunks of piston in case .
(so we assume it's in time)
but it is all back together, gets spark, etc., but won't start.
just backfires thru carb (literally, backFIRES)
can anyone give us anywhere to start that might cause this backfiring thru the carb, so that we may fix it? (remember, certified & proven/experienced kawi mechanic told us he timed it correctly)
thanks
-racer36
Old Nov 16, 2004 | 05:50 PM
hondabuster's Avatar
Hes capible of making mistakes too. About the only thing that causes the backfireing, is valve timing. Either the valves are grossly out of adjustment, or the cam timing is off. If he assembled it with the chain slack, on the wrong side, thatll do it. The slack needs to be on the tensioner side.
Old Nov 16, 2004 | 10:41 PM
springdrl's Avatar
I second that motion. Sounds like a timing issue to me.
Old Nov 20, 2004 | 08:17 AM
AlaskaBayouGuy's Avatar
Backfire comes thru the carb - caused by either way too lean of a mixture or the air fuel charge is being fired way too soon -- After fires - often confused with backfires - come out the exhaust and are caused by way too rich a mixture or charge being fired way too late. Timing and mixture would both be a place to look.
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
blpersinger
Jul 15, 2015 09:56 PM
