installed a dayco hp 2017 on p700 other than the dealer where else can i buy shims
i have the part #s for the shims for my driven clutch, but i was wondering if you can buy the shims online anywhere or do i have to go to the dealer? and also what do you guys use to measure the pressure you put on your belt to measure the deflection other than a fish scale?
I used a long socket extension or a straight egde and a tape measurer. I have shims that i pulled out of mine and ones new in the pack still if you need some.
Or you can get them from here also
http://www.buykawasaki.com/Default.asp?
Also rotate the belt around a few times after you install it and the belt will tighten up.
jrooker6
Apr 23, 2016 07:36 PM
