Pink Primary on a P-360
I have the black secondary & have tried the red primary & hated it.. I'm not as familuar with the primary spring as the secondary. If I elected to try the pink on my prairie, what differnce might I notice if any over stock?
I also have the black secondary spring and have been experimenting with the primary spring. I have the stock P700 primary in mine now noticed some improvement but not worth the effort. I have the pink on order should be here the first of the week, will know more when it gets here and the weather breaks if interested will let you know. I'd really like to have some more compression in the engine but no luck with a piston yet.
I've got the pink primary in with around 8hrs. riding time on it. First impressions has a low stall as soon as you hit the gas it moves, somewhat better shift out and seems to stay in the power better. It was not as big of an improvement as I was looking for but noticeable, this was at low trail speeds 10-12 mph tops. For the type riding that we do I would put one in just for the low stall, I'm sure for different riding style and or use it might be more noticeable.
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
