650 Coolant leak..FYI
Old 12-21-2004 | 12:42 AM
kodiac1's Avatar
Default 650 Coolant leak..FYI
For a while now I have been smelling coolant especially after a cold start.I looked and looked and could not find it.I know that even a drop can smell so I knew it was small.Well I found it tonight. The hoses that connect to the thermostat housing were loose,or at least one was.When I finally got the front fender off so I could get to the hose clamps they were VERY loose.I am not sure if the hoses are starting to shrink with some age or if maybe the front motor bolt being loose allowed the engine to drop enough to pull the hose but they were loose.It was the one coming off the frt cylinder head.It makes a 90 degree turn right at the housing.If you smell coolant and can't find it this is probably it.
02 650 camo
Old 12-21-2004 | 01:46 PM
trx450's Avatar
I found that, on the radiator hose down to the waterpump, (on the water pump end)the clamp was broken from OVER TORQUING at the factory! I found it 30 miles from the truck, out in the mtns. of WVa. Luckily, I was able to use a tie-wrap as a temporary hose clamp......
Old 12-21-2004 | 08:13 PM
deerchooper's Avatar
i will have to check those places out. ive been smelling a little antifreeze when i get her soaked, like when i wash it when its running or running in the water. sometimes i think its me, because the sniffer aint like it used to be.
Old 12-21-2004 | 11:10 PM
kodiac1's Avatar
The thing I hate about coolant is you can smell one tiny drop.Mine was dripping down the hose and hitting the front exhaust pipe.I guess maybe it's good you can smell it.
02 650 camo
Old 12-22-2004 | 09:42 AM
trx450's Avatar
kodiac1----- I am that way with gasoline. I can smell 2 drops, from a mile away.....................
Do check that hose clamp on the water pump inlet. It is easiest to remove the engine skid, and jack it up, and crawl under.
Old 12-22-2004 | 10:31 AM
kodiac1's Avatar
Will do!
02 650 camo
1ArmBandit
55
10-14-2015 10:03 PM
essonlaker
09-10-2015 02:12 PM
Randy Lee Frye Sr.
09-09-2015 03:30 PM
Kenidah
09-07-2015 08:50 PM
Quick Reply: 650 Coolant leak..FYI
