Spark Plug question
Old Dec 31, 2004 | 06:02 PM
Vunit's Avatar
Default Spark Plug question
In AtvAction mag they did a test on the Lakota and and say to run NGK DR7EA spark plug. In my lakota which is far from stock i'm running a NGK DR8EA. What is the difference and between them and is it ok for the quad.
Old Dec 31, 2004 | 06:27 PM
rolsmojave3's Avatar
i think that the 7 shows that it is hotter or colder...can't remember which way the numbers go
Old Dec 31, 2004 | 07:24 PM
Vunit's Avatar
So it really does not matter which one i run in my lakota
Old Dec 31, 2004 | 08:51 PM
hondabuster's Avatar
http://www.ngk.com/sparkplug411.asp, at the bottom, it explains the numbering system. The lower number, is a hotter plug.
Spark plugs dont create heat, they just pass it on to the head. A hotter plug transferrs less heat than a cold plug. Hotter plugs are used to burn deposits , that a normal plug cant...due to jetting or oil burning.
If youve been using the 8, and it doesnt foul, then keep using it.
Old Jan 2, 2005 | 07:42 PM
Vunit's Avatar
Yeah i been using it since i got my quad and even when i put my pipe and jet kit on, it has never fouled out on me before so i'll keep using it like you said. Thanks
chammerbeck
Jul 17, 2015 08:06 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
D-Hagz
Jul 4, 2015 02:19 AM
