Plow / Winch combo problems
Old Jan 11, 2005 | 04:34 PM
Bonza's Avatar
Default Plow / Winch combo problems
I have the same combo. On mine, the plow contacts the frame before the winch hook runs out of travel. To help with the amount of lift, I installed a front spring kit purchased off Ebay. That reduced the amount of "dive" that brought the front down (compressing the struts) before lifting the plow up.
We only had one snow last year where I needed to plow with the Prairie. It worked just fine. Only problem is that the battery runs down faster than can be recharged since the winch is pulling a lot of amps.
Bob
Old Jan 11, 2005 | 11:06 PM
dogg's Avatar
Has anyone tried mounting a plow under the Ricochet skid plates. I have a Warn angled plow and am having a hard time trying to find a mount for the plow. The one that came with it uses U bolts in the front and back and the P700 doesn't have a spot for the rear U bolts. Went to the dealer and since I bought the plow setup online, they were of no help. I guess I need to contact Warn or take off the skid plate and try something else. Help!!!!!
Old Jan 11, 2005 | 11:58 PM
MikeRhyne's Avatar
dogg,
I have the Ricochet & warn plow setup and I notched the skid plate for the clamps and drilled holes in it to put the u bolts through. I hate the way it hangs down but I just take it off come spring time so I don't get it caught up on the rocks.
I also use the warn synthetic winch rope for lifting so I don't wreck the winch cable.
Mike
Old Jan 12, 2005 | 09:01 AM
dogg's Avatar
Mike,
I will have to take a closer look at the setup. I looked for a connection where the U bolts would fit and things just didn't seem to align up. I will flip it up again and give it a shot. Do you have any pictures?
Dogg
Old Jan 12, 2005 | 09:46 AM
  #15
MikeRhyne's Avatar
Dogg,
Give me a couple of days for pictures as I have people in refinishing out wood floors and its packed up somewhere...
Thanks,
mike
Old Jan 12, 2005 | 11:08 AM
  #16
robsjeepyj's Avatar
As to the winch. I take the cable off for the winter and put on a seat belt out of an old car. Real strong and wont get messed up. If it does who cares.
After I get the cable off and rolled up. I take the seat belt with a piece of duct tape on the end and stick it to the drum. Then just reel it in. The duct tape just holds it to start then the wraps take over. just like the cable.
Rob
Old Jan 12, 2005 | 10:35 PM
  #17
GOODGUY's Avatar
whats the distance between the pushtube mounts. I have a country cycle pushtube and the mounting brackets do not interfer with the skid plates. Off of the top of my head its 14.5". The only disadvantage is you loose ground clearance. In the spring I will take off the mounts....only 8 bolts total.
If your warn is 14.5" you can use these mounts....
Old Jan 13, 2005 | 12:56 AM
  #18
mpap's Avatar
I have the Kawi skid plates what I did for the back Is cut some off and milled a slot I dont have to take my skids off to mount the plow, It is a moose plow, Anyone want picture of how I did it just aak I will take some works great, Except we get no snow anymore LOL
Old Jan 13, 2005 | 11:56 PM
  #19
MikeRhyne's Avatar
Dogg,
Here are some pictures - they are a little fuzzy since my camera doesn't focus close that well.
Pic1
Pic2
Pic3
Pic4
Old Jan 14, 2005 | 11:58 AM
  #20
dogg's Avatar
Mike,
Your pictures were fine...Thanks. For a minute, I thought I was trying to install the thing reversed! I went back out and looked at it again and decided to take off the skid plate to really see what I was working with. After doing so, I found 1 exact spot where the mount would fit. Now I am going to put the skid plate back on and try and hit those exact spots with the drill. The only spots are in the gap where the frame angles meet. Maybe I will try and mark them from the top. I think the edge notching is going to be the most difficult. Good thing its not snowing yet!
