03 P650 carb jetting
Old Mar 16, 2005 | 01:49 PM
Plainsman's Avatar
Default 03 P650 carb jetting
The washers are bought at Radio shack. Use the search to find the part #.
The #4s still vary thickness in the sac. Get a micrometer so you can find 4 of them that are .02. Im stock and just put 2x.02 under each needle. More throttle response and the popping is gone. I think it just made it a bit richer.
I found variance from .02-.025 so you do want to verify the thickness. A $10 dial caliper will do that for you.
Good luck!
Old Mar 17, 2005 | 06:58 AM
rivermud's Avatar
I agree, I also some some varience in the #4 washers and all were between .020 and .025. You can go to .070 without any problem if needed.
Cole Hadden
Jun 15, 2025 09:05 AM
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Jul 29, 2015 09:41 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
