Cann't Shift
sounds like the ajustment is off, to ajust it take off that plastic cover on the crank case and you should see a nut and bolt. loosen the nut, tighten the bolt till it gets hard then loosen it till it gets hard and then screw the nut back on and tighten it but hold the boltwith the screwdriver when you are tightning the nut orelse it will move
yeah holeshotz is probably right, give that a try and see what happens, also all lakota's have bad clutch and they get even worst when you start modding them. I try to adjust mine ever few months or so, and i seems to be holding up fine even with all my mods. At first when my lakota is cold it's hard for me to shift but once it warms ups its fine!
