Torn BF CV Boot
Old Jun 12, 2005 | 11:57 PM
bruteboy's Avatar
Default Torn BF CV Boot
Today I went out and my rear CV boot ripped. I was wondering if it is hard to replace it myself. My warrinty in over and I want to save money and do it myself. If anyone has done this tell me what steps to take. Thanks.
Old Jun 13, 2005 | 01:29 PM
THECVMAN's Avatar
The only way to remove the outer cv joint is to hit it off the shaft with a hammer. The problem with this is that you may damage the joint in the process so I would only recommend this if your replacing the cv joint anyway. If you are not replacing the outer cv joint then the safest thing to do is put it on from the inner cv joint side. The inner cv joint is very simple to remove. First you'll want to remove the clamps from the boot (you'll want to buy the additional clamp kit for $2). Being careful not to puncture the boot you can pry up on the tabs that hold the band in place or just cut by putting a screwdriver under them and prying up to give you enough room to get the metal snips under them. Once the boot is free slide it back toward the outer cv joint to expose the inner components. You'll find a large retaining clip that goes around the inside of the joint just above the ball tracks. Remove the clip by getting behind it with a small screwdriver. Once this clip is removed the inner cage, race, *****, & shaft will come out all together (wrap your hand around this to prevent the ***** from falling out all over the place). You'll find a retaining clip on the back of the shaft, remove this with retaining clip pliers or a large screw driver to spread the clip open. Once this is removed you'll be able to remove the cage, race, & ***** all together at one time. No your ready to install it on your new half shaft. Make sure the boot goes on first. Then place the cage, race, & ***** on the shaft making sure that the tapered side of the cage and race are facing toward the outer cv joint. Install the clip to hold it onto the shaft. Then fill the inner cv joint housing with grease and place it over the cage, race, & *****. Install the large clip. Now pull the boot down and install the large clamp. Then take a screw driver and place it in between the small part of the boot and the shaft and push the inner cv joint in all the way until it bottoms out. Then pull it back halfway (or to the mid range of the inner cv joint) and remove the screw driver and install the small clamp. Your now ready to install the axle back in the vehicle. If you have any questions or concerns you can PM me and I'll be glad to help.
Thank you,
Danny Walburn
"thecvman"
95scramblerruben1033
Sep 23, 2015 06:29 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
jankerstien
Sep 21, 2015 03:09 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
