water in oil HELP!!
Old Jun 22, 2005 | 02:34 AM
mont8's Avatar
Default water in oil HELP!!
93' mojave
last weekend i noticed water dripping from the water pump. I thought it was just hot, but later i touch it with my finger and sure enough i had oil in the water. the site glass on the side also had a milky look to it. Is the head gasket my problem or is their a way water can get in from the water pump.
and when i replace parts do i need head gasket and water pump seals and gaskets, both, or is there more to it than that
Old Jun 22, 2005 | 12:32 PM
action450s's Avatar
Bad head gasket or cracked head or cracked block. Take it apart to see if its the gasket, if not have somone check the head.
Old Jun 22, 2005 | 12:36 PM
tuffEnuf's Avatar
Might want to state what model quad it is?
Old Jun 22, 2005 | 12:37 PM
tuffEnuf's Avatar
MY Bad, didn't read 93 Mojave
Old Jun 22, 2005 | 01:28 PM
holeshotz8436's Avatar
i think this is a common problem with ther mojaves..........im pritty shure that its casued by a seal going bad in the water pump and it allows oil to seap from the engine into the coolant.........if you replace that you should be good to go........mojave people help him out!
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
