02 bayou oil problem
and make shure its not a car oil because most car oils dont meet standars for atv engines and arnt wet clutch compatable......the honda oil in the gold bottle is decent but my prefrence is royal purple max cycle
10W-40 is OK so long as the air temps stay in the low 90's. If you ride in areas where daytime temps hit upper 90's or low 100's, go with 20W-50. I used to run 10W-40 in my Bayou 250 and found the engine running quite hot in the summer. Switched to 20W-50 and what a difference it made.
